Date/Time: Mon, 29 Apr 2024 10:16:15 +0000
MB Trading Forex
View Count: 1961
[2013-09-12 21:24:21] |
No. MB Trading is not supported.
[2013-10-11 18:57:33] |
We will not spend the time integrating to MB trading. At this point, this is pretty much out of the question. For more information about our position, refer to this page here: Our Experience with E-Signal MB trading will need to follow the new Data and Trading communications protocol documented here: https://www.sierrachart.com/index.php?l=doc/doc_GeneralDataTradeServiceProtocol.php We recommend that you contact them and encourage them to adopt this protocol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-11 18:58:11
