Date/Time: Mon, 29 Apr 2024 23:12:11 +0000
cumulative delta for larger orders
View Count: 4228
[2017-10-19 15:26:16] |
User884550 - Posts: 149 |
is it possible to filter CD by order size? could not find it in the settings what if i want to follow delta for orders above 50 only? |
[2017-10-19 17:32:08] |
Yes you can. Refer to Volume Filtering here: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-20 00:09:22] |
User19165 - Posts: 346 |
Your expectation for this to be in the indicator settings is standard across every platform, so I understand that. In case you want to plot different filters on multiple CVD indicators on the same chart, take a look at this thread. Just like you, I expected (and still do) this to be in the indicator, but alas. Cumulative Delta volume filter as input |
