Date/Time: Sat, 18 May 2024 15:24:31 +0000
Volume by Price efficient settings
View Count: 884
[2017-10-06 09:23:31] |
samual sprat - Posts: 343 |
Hi, I use VbP on multiple fixed time ranges, e.g. daily, weekly, monthly. I like to see historical levels so load up 4000+ days of data. It runs okay on my machine, it's a quick machine, but is there a way to make it faster when loading into intraday timeframes? Maybe there's some options under chart settings that would help? The charts run in their own instance and so would that mean I could configure global data settings just for that instance differently? Btw, any news on the 64bit Sierra update? Thanks Sunny |
[2017-10-06 22:35:02] |
You need to set the Intraday Data Storage Time Unit to 1 minute and re-download the Intraday data, in that instance: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) Btw, any news on the 64bit Sierra update? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-06 22:36:18
