Date/Time: Mon, 29 Apr 2024 13:20:28 +0000
Current % of ATR
View Count: 1713
[2017-10-03 17:09:59] |
Dom7364 - Posts: 257 |
What would be the best way, to display on a chart as a percentage, the figure % versus Average range? For example if the average range is 100 points and we have done 20 points, this would show 20% and so on.. Thanks |
[2017-10-03 17:41:27] |
Have a look at calculating this using the Arithmetic studies: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-04 06:40:14] |
Thank you. How do I get the current range? Difference between high and low doesn't seem to work.
[2017-10-04 18:42:31] |
You can use the Bar Difference study for this: Bar Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-01 10:43:29] |
Ackin - Posts: 1865 |
Dom7364) Hi, you can download study for free from our CZ/SK forum (just Study in dll file, not code). Study: Ratio MaxMin Range contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:35:15
