Date/Time: Thu, 23 May 2024 16:53:01 +0000
Fibonacci Time Zone
View Count: 1634
[2017-09-29 19:53:16] |
User609717 - Posts: 1 |
Is there a tool available that rather than a Fibonacci Price Retracement, instead uses Fibonacci levels based on time. I noticed the time projection tool, however it doesn't appear to use Fibonacci ratios. Any help would be appreciated. Thanks! |
[2017-09-30 05:30:21] |
There are the Time expansion and Time Projection drawing tools: Chart Drawing Tools: Time Expansion Chart Drawing Tools: Time Projection You can set any time intervals including based upon Fibonacci levels. Those are adjustable in the tool configuration. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
