Date/Time: Thu, 02 May 2024 16:57:24 +0000
[Programming Help] - Order Flow Chart Setting
View Count: 2958
[2017-09-19 14:38:35] |
User245645 - Posts: 36 |
I can not set my chart in the same way that it is represented in the Ninja chart. Because my volumes appear in my chart in red highlighted by the arrows and in Ninja no |
My Sierra.jpg / V - Attached On 2017-09-19 14:38:12 UTC - Size: 334.55 KB - 1660 views NINJA Michael Valtos.jpg / V - Attached On 2017-09-19 14:38:18 UTC - Size: 222.31 KB - 2052 views |
[2017-09-19 18:03:39] |
Refer to the documentation here for Text Coloring Methods: Numbers Bars: Numbers Bars Text Coloring Methods You need to read and understand the documentation and configure the Numbers Bars study as you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-04 02:14:21] |
Gerardo Avalos Villegas/CR-12049 - Posts: 1 |
Saludos, me puede enviar una guía para configurar orderflow. Gracias. |
[2019-02-04 19:20:43] |
We just have this documentation here: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
