Date/Time: Sat, 18 Jul 2026 05:43:59 +0000
Cumulative Delta Volume odd chart
View Count: 4891
[2013-09-06 13:26:34]
User66752 - Posts: 4
I feel that CD chart is not showing correct information in my platform.
here's 1 min GOLD futures today Sept 6, 2013
http://screencast.com/t/cYoIwSpw
as you see at 8.30 AM EST CD candle is not in line with bullish price candle. Could you suggest why is this happening?
I'm using Velocity Futures as my broker
chart settings are
http://screencast.com/t/ZMKufCfU5h
http://screencast.com/t/QMpGBe92
http://screencast.com/t/DHO8zMUUiw
http://screencast.com/t/y8rDcTiGfBl
Thanks!
Denys
[2013-09-06 14:36:33]
Sawtooth - Posts: 4341
It looks like you are using TT data :)
Whether the trade happened at the bid or the ask is set by the data feed. SC just plots what it gets.
A quality data feed like IQFeed will solve this.
For data feeds with poor bid/ask accuracy, try using the Cumulative Delta Bars - Up/Down Tick Volume study instead.
[2013-09-06 14:59:00]
yes, I'm using TT. how reliable is "Cumulative Delta Bars - Up/Down Tick Volume" study?
can I use it for gauging market sentiment instead of original "Cumulative Delta Volume" study using TT feed?
thanks for response!
Den
[2013-09-06 15:10:44]
I use TT data as well. It is fast and reliable, but has poor bid/ask accuracy.
The Cumulative Delta Bars - Up/Down Tick Volume study with TT data is very close to the Cumulative Delta Bars - Volume study with IQFeed data. Attached is a comparison I did last year.
The upper panel is Cumulative Delta Bars - Volume study with IQFeed data.
The middle panel is Cumulative Delta Bars - Volume study with TT data.
The lower panel has cumulative delta bars made from Up/Down ticks with TT data.
Date Time Of Last Edit: 2013-09-06 15:11:43
imagecum_delta.png / V - Attached On 2013-09-06 15:09:40 UTC - Size: 45.1 KB - 2031 views
[2013-09-06 15:17:44]
thanks tomgilb , that was very helpful!
[2013-09-06 18:32:51]
The information given by Tom is all good and correct. We do not have anything further to offer ourselves.
