Date/Time: Thu, 16 May 2024 10:11:19 +0000
Login Error
View Count: 1081
[2017-09-09 03:26:40] |
BruceWilson - Posts: 14 |
Hi, After a period of absence, I have upgraded to service package 5 and tried logging in. I have started with a clean install. Am having a connection error, both with VPN on and also off. Internet connection is fine (I'm writing this just minutes after the login error). Please advise what I need to do? Thank you and best wishes Bruce |
Sierra Chart Login Error.jpg / V - Attached On 2017-09-09 03:23:52 UTC - Size: 30.29 KB - 243 views |
[2017-09-09 21:31:37] |
There is some connectivity problem with even connecting to the Sierra Chart Web server . Refer to this page: HTTP Communication Errors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-09 21:32:08
