Date/Time: Wed, 15 May 2024 02:10:58 +0000
Volume by Price question
View Count: 903
[2017-09-05 02:44:07] |
User99934 - Posts: 227 |
At 22:10, why is the volume row at 247 colored green? I would think it would be no color because neither bids or asks are dominant to other level on diagonal basis. The chartbook is attached. http://www.sierrachart.com/image.php?Image=1504578269137.png Since the diagonal option is new on volume by price and the manual is not updated yet, I would assume you are using rules similar to Numbers Bars: Background Coloring Based on Diagonal Dominant AskVol BidVol Difference - Actual to determine coloring. If so, should not the top and bottom of each bar not have coloring as well because there is no higher or lower level to compare it do? Just wondering. Thanks. Date Time Of Last Edit: 2017-09-05 02:46:37
Chartbook2.cht - Attached On 2017-09-05 02:26:58 UTC - Size: 40.78 KB - 308 views |
[2017-09-05 18:54:30] |
We will work on documentation for this. The coloring is based upon either the bid or ask side being more dominant using diagonal comparisons. At each price level one side will always be more dominant than the other. There will be changes to the coloring at the top and bottom for the diagonal calculations in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-05 18:54:55
