Date/Time: Tue, 14 May 2024 16:28:38 +0000
RTH Daily charts not Back Adjusting
View Count: 953
[2017-09-04 14:05:38] |
User565119 - Posts: 33 |
Hi, My RTH futures daily charts are all set to the specific pit times. I have them set to "volume based, back adjusted" for rollover in settings. I do not think it is back adjusting as there are large gaps. Also happens on RTH TPO charts, throwing me off to a large degree. Chart is set to 8:20 to 14:59:59 est. 6E pit hours. Date Time Of Last Edit: 2017-09-04 14:07:11
RTH Erros.PNG / V - Attached On 2017-09-04 14:05:13 UTC - Size: 78.45 KB - 291 views |
[2017-09-04 16:25:25] |
Follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-04 20:56:06] |
Did this a few times. Has not helped. Will keep trying. Any other suggestions?
[2017-09-04 23:45:43] |
You should not have any problem at this. Make sure you have followed through all of the steps: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data You do not have to do this a few times. Just once. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
