Date/Time: Tue, 14 May 2024 07:48:58 +0000
add some ticks to initial balance
View Count: 803
[2017-09-03 09:42:33] |
olatrade - Posts: 10 |
hi, i like to plot the initial balance with 4 ticks added to the upside and 4 ticks to the downside what is the easiest way to do that ? ie: IB high is 1255 and IB low is 1250. I like to plot a line at 1259 and at 1246 |
[2017-09-04 18:43:10] |
For this you need to use the Study Subgraph Add a study. Refer to: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
