Date/Time: Sun, 12 May 2024 12:25:09 +0000
Renko Bars not painting correctly during fast market movement.
View Count: 972
[2017-08-24 23:05:11] |
Xfanman - Posts: 5 |
During a fast move in price the Flex Renko bars I'm using will not paint correctly. If I refresh the chart they will be as expected. Is this a function of the Chart Update Interval? I've adjusted it to a faster update and experience it at both 10ms and 100ms. This can't be typical behavior so I assume it's a settings issue I haven't configured correctly? Please see the two charts below. The first taken after a quick burst on CL and the second chart after I refreshed it. -- Thank you. https://gyazo.com/af0e8feb651417a2b46e11c99294d46c https://gyazo.com/656524f6dde79b697018da098d8a04dc |
[2017-08-25 03:11:30] |
We will only accept chart images posted following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Make sure Sierra Chart is set for a tick by tick data configuration: Tick by Tick Data Configuration: Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-25 13:43:29] |
Thank you, my settings were set to Seconds not Ticks. GC is moving very quickly this morning and I am not encountering the same issue. Looks like that fixed it. In the future I'll make sure to post images in the desired manner. Thanks much...Scott |
