Date/Time: Sat, 04 May 2024 21:04:26 +0000
[Programming Help] - Indicators for Pullback on Number Bars
View Count: 1874
[2017-08-14 02:58:51] |
User99934 - Posts: 227 |
Any possibility to allow indicators to work on the pullback column(s) of Number Bars?
[2017-08-14 09:27:07] |
No, in general this is not supported. You can custom develop whatever you want though or hire a programmer to do that. There is no need to rely upon us for that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-14 09:27:35
[2017-08-14 12:38:42] |
FYI, I am not looking for a specific indicator to work on the pullback column(s), just the ability to include it in the calculation in any study. Right now, I would be interested to see it work with the number bars calculated values study, cumulative delta bars, and bid ask depth bars.
Date Time Of Last Edit: 2017-08-14 13:14:44
[2017-08-14 13:35:05] |
This is already supported with the Numbers Bars Calculated Values study: Numbers Bars: Numbers Bars Calculated Values Input Descriptions You need to set the Input Show Pullback Column Values to Yes. These other studies do not use the pullback data. So this is not even technically possible to begin with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-29 20:49:28] |
User881696 - Posts: 16 |
When "Input Show Pullback Column Values to Yes" is true, can that data be used in calculations when creation an ASCIL automated program, or a simple trade alert? I.m trying to use it, SG37 AND SG38, in my calculations but I get nothing. Thanks
