Date/Time: Tue, 07 May 2024 02:15:20 +0000
Multiple limit orders to enter, while using attached orders - WITH ONE CLICK ON DOM
View Count: 2001
[2017-08-09 19:03:36] |
User299392 - Posts: 216 |
I did not see a way where I could on one click have several limit (entry, or parent orders) be entered with contingent stop and target orders ATTACHED TO IT. Am I missing something or this feature is not existent. In others words, and I will keep it brief - I wish to enter - 1 contract to buy at current bid price (say 5900) and 1 contract each at the same time (with the same click) 4 ticks apart each (below the current bid, which is to say 1 limit contract to buy each at 5899, 5898, 5897, 5896) on the DOM as limit orders under the main order to cost average in fast markets and then depending on the fills - I should have my stops (say at 5890) and targets (say at 5910) be placed with scale in and scale out feature. Seems like I cannot do the entry part with just one click. However, stops and targets configuring is possible using attached orders feature, which part I know. PLEASE HELP! |
[2017-08-11 16:51:21] |
Merlin - Posts: 81 |
I'm not sure why, but this has been marked as "[User Discussion]", which by definition means that Sierra Support won't follow or comment on it. If that's not what you intended, I'm not sure what you need to do to fix it. You can try posting a message making it clear you're asking for help from Support, but if that doesn't work you might have to just re-enter the request again as a new thread. Personally, I don't know the answer to your question, but I'm very curious to find out if this is possible. Merlin |
[2017-08-11 17:40:43] |
What you are asking for is not supported and you would have to develop this using ACSIL or hire a programmer.
[2017-08-11 17:58:47] |
TSiSVT - Posts: 21 |
I have interest in this as well. Consider implementing it in a future release.
[2020-06-25 15:56:31] |
User805816 - Posts: 6 |
i would also support this request. for my trading it would add significant value! Thanks!
[2020-08-28 17:03:30] |
User964132 - Posts: 93 |
This would be nice indeed!
[2020-10-01 21:15:43] |
User519334 - Posts: 1 |
Same here. Please consider.
[2020-10-02 13:19:22] |
User90125 - Posts: 715 |
+1
[2020-11-02 10:07:03] |
+1
[2022-05-26 23:28:06] |
BillsSBC - Posts: 29 |
+1
