Date/Time: Sun, 19 May 2024 10:20:48 +0000
Ask Volume
View Count: 829
[2017-08-08 14:53:03] |
User245645 - Posts: 36 |
How do I move up Volume Ask over BID/ASK data ?
Volume Ask Volume.png / V - Attached On 2017-08-08 14:51:58 UTC - Size: 130.28 KB - 268 views |
[2017-08-08 15:44:33] |
What version of Sierra Chart are you running? And what is the Tick Size of the symbol in Chart >> Chart Settings? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-08 17:37:40] |
The version is 1590 Attaced version and setting |
Chart Setting.png / V - Attached On 2017-08-08 17:37:10 UTC - Size: 52.92 KB - 276 views Version.png / V - Attached On 2017-08-08 17:37:15 UTC - Size: 6.85 KB - 240 views |
[2017-08-08 18:19:13] |
We think we know why this happens and we will resolve it but really what you need to do to resolve it now is set Sierra Chart to a tick by tick data configuration: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
