Date/Time: Sat, 04 May 2024 09:18:36 +0000
text on drawings
View Count: 572
[2017-07-21 12:17:48] |
User884550 - Posts: 149 |
is it possible to add text to drawings above or below the price? just using text tool ontop of drawings is somewhat uncomfortable |
[2017-07-21 17:24:45] |
Some Chart Drawings allow you to set text on them. Refer to: Chart Drawing Tools: Modify Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
