Date/Time: Mon, 20 May 2024 01:15:49 +0000
Click Trader in Sierrachart
View Count: 2282
[2017-07-03 17:53:56] |
User989712 - Posts: 27 |
I see that there are keyboard shortcuts, but, is there any way to do the following, without custom code, perhaps with public code, in SierraChart? Shift - Left Mouse = place LONG Stop Limit / Limit at cursor price Control - Left Mouse = place SHORT Stop Limit / Limit at cursor price Control Shift Up Arrow = place LONG at Bid Ask Price Control Shift Down Arrow = place SHORT at Sell Bid Price Space Key = Go Flat (just for the instrument on the active chart, not other charts) Quantity and other trade parameters taken from the current Trade Window settings I could do this in Ninja but I had to code it myself. Not ready to dive into custom coding on a new platform. Thank you. |
[2017-07-06 08:07:12] |
Control - Left Mouse = place SHORT Stop Limit / Limit at cursor price You can use the Chart DOM for this. Refer to: https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM Control Shift Up Arrow = place LONG at Bid Ask Price Control Shift Down Arrow = place SHORT at Sell Bid Price Space Key = Go Flat (just for the instrument on the active chart, not other charts) Basic Trading and the Trade Window: Trading Keyboard Shortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-06 08:07:45
[2017-07-08 16:01:32] |
I never use a DOM.... On the other...the options are against bid / ask / market. these are all the current drawing point on the chart what I want to do is to have an order placed where the cursor is on the chart...is this possible? This order price is not related to the current bid / ask / market. |
[2017-07-08 17:43:53] |
This is an integrated trading ladder on the right side of the chart. You should give it a try. You can also activate the Chart Values tool at the same time to have a horizontal line across the chart at the price level you are pointing at on the trading ladder/DOM.The particular order actions that are performed with the left and right clicks and also based upon the particular column can be configured through Global Settings >> Chart DOM Settings. The only other way is to use the standard chart trading functionality: Chart Trading and the Chart DOM: Chart Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-08 18:07:41] |
Ok, will check it out, but usually dom thingys only have a certain range.....will try next week and tell you if it works for what I do the standard chart trading is good but is much slower than point / click with key combo / trade entered but a further question.... programmatically...in Ninjatrader 7 it is possible with custom unsupported code to access the chart price at the cursor, that was the hard part. Then entering the order is easy. I had guidance from the community at futures.io that resulted in a very nice click-trader. Has anyone done this already in Sierra Chart? Perhaps I should ask on Futures IO? I have no idea why it is not part of the standard packages like NT, Sierra Chart, etc Once a person can simply click/key combination and put in a trade based on the other parameters in the Trade Panel.... |
[2017-07-09 06:18:20] |
Yes this is supported. Refer to:ACSIL Interface Members - Variables and Arrays: sc.ChartTradingOrderPrice For order entry examples, refer to the *OrderEntry*.cpp files in the /ACS_Source folder with Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-27 08:13:21] |
Dingor - Posts: 13 |
Someone has the code asked by User989712 ? It would be very useful but I am not able to code it by myself Thanks in advance |
