Date/Time: Wed, 15 May 2024 03:37:00 +0000
Data Error In File - Can't Correct the Error
View Count: 601
[2017-06-29 17:27:48] |
User930315 - Posts: 55 |
I've followed the directions in the Intraday Data Editor page and opened a 10s chart. When I open Chart Values window and click on the problem bar it shows a value of -45. (This is on a YM chart.) I right click on the bar and select Edit/Download Data and the values shown are not the value of the bar I've selected. If I click "Go to Date-Time" and enter the correct info it still does not display the values for the problem bar. I've deleted and reloaded all data and the problem bar comes back so it's apparently coming from my data provider. When I export bar data to a text file I can find the problem data, but when I Export and Edit Intraday Data there are only about 20 bars per day shown and the problem value does not show up. Am I missing something? Date Time Of Last Edit: 2017-06-29 17:28:25
[2017-06-29 17:40:15] |
Post an image of the chart showing this data error. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-29 17:49:23] |
With overlays: http://www.sierrachart.com/image.php?Image=1498758491257.png Without overlays: http://www.sierrachart.com/image.php?Image=149875853519.png |
[2017-06-29 18:15:08] |
The problem is the data error is in the YM June contract data. You cannot correct it as you currently are. The easiest thing to do is to follow the instructions here and re-download data for the June and September symbols: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#ReDownloading First though, follow the instructions here to set Sierra Chart to use the Sierra Chart Historical Data Service : http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#UsingSierraChartHistoricalData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-29 18:15:36
