Date/Time: Tue, 14 May 2024 04:31:08 +0000
using target troubles with Crude Oil
View Count: 825
[2017-06-29 14:44:25] |
User1193154 - Posts: 54 |
Hello, second time that instead of 2 points target system close the trade and give me only 1 point. Why? Ty for assist me Regards, Flavia Litardi |
[2017-06-29 17:18:29] |
Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/TradeActivityLogAnalysis.php#SupportAssistedTradeActivityLogAnalysis In this case, there is no additional cost for looking at this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-29 17:24:44] |
Hello, ty. Here TradeActivityLog.dat Regards Flavia Litardi |
Private File |
[2017-06-29 17:40:54] |
This is not enough information. We need what is requested here: http://www.sierrachart.com/index.php?page=doc/TradeActivityLogAnalysis.php#SupportAssistedTradeActivityLogAnalysis We cannot help you without every detail provided. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-29 18:01:54] |
This ? 1521473553 1521712800 1521732509 1521747355 Ty |
[2017-06-29 18:07:19] |
This is not enough and we do not know what you are referring to. Make sure you are setting the Attached Orders on the correct Trade Window from the chart or Trade DOM, you are trading from. Refer to: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SettingsNotApplying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-29 18:17:56] |
Sorry but you request diffent things everytime. Problem about my opinion, is because have to send a screenshots. Here them Ty |
Attachment Deleted. Screen Shot 06-29-17 at 08.15 PM 001.PNG / V - Attached On 2017-06-29 18:17:34 UTC - Size: 163.65 KB - 236 views Screen Shot 06-29-17 at 08.15 PM.PNG / V - Attached On 2017-06-29 18:17:45 UTC - Size: 159.86 KB - 228 views |
[2017-06-30 16:43:22] |
Make sure this option is disabled: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#UseServerSideBracketOrders We think it already is based upon the Trade Activity Log. And enable this option: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#AdjustAttachedOrders Let us know if that resolves the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-30 17:16:29] |
Hello, Ty for help. I did'n undastend , sorry. Link you sent are pages with many informations and arguments. No-problem, hope never occur same problem. Happy week-end Flavia |
[2017-06-30 17:31:23] |
Enable this option: Global Settings >> General Trade Settings >> Adjust Attached Orders to Maintain Same Offset on Parent Fill Disable this option: Global Settings >> General Trade Settings >> Use Server Side Bracket Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-30 17:36:03] |
Great! Find all you suggest to check. Thank's again |
