Date/Time: Mon, 20 May 2024 14:17:14 +0000
Gap in Weekly Historical Data
View Count: 541
[2017-06-26 14:19:13] |
User104854 - Posts: 441 |
I have a historical chart of the 30 Yr Bond (ZBU7) and there are 3 months of data missing. I've attached a screenshot of the spreadsheet. The gap is between 2-27-17 to 5-31-17. I'm using the continuous futures contract - volume based rollover. Is there a different setting I should use to fill the gap? Maybe an @ZB option for a continuous contract? I've tried to delete and reload and it isn't working. Thanks.
Weekly-ZBU7.png / V - Attached On 2017-06-26 14:16:35 UTC - Size: 333.24 KB - 234 views |
[2017-06-26 15:21:45] |
Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
