Date/Time: Sun, 19 May 2024 00:29:35 +0000
NUmbers bars
View Count: 797
[2017-06-23 14:10:44] |
User291323 - Posts: 8 |
Good afternoon, enclosed you can find two snaps from my Sierra chart. Till today numbers bars (collors) have worked properly, from today I can see just green a red colors. Could you help me please? Ivan |
IMG_1194.jpg / V - Attached On 2017-06-23 14:09:17 UTC - Size: 89.1 KB - 216 views IMG_1195.jpg / V - Attached On 2017-06-23 14:09:28 UTC - Size: 99.61 KB - 214 views |
[2017-06-23 17:01:38] |
What is the Column 1 Text Coloring Method Input set to? What is the Column 1 Percent Compare Thresholds Input set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-23 17:11:41] |
Column 1 text colouring method is: Based on Diagonal Dominant side AskVol Bid Vol Percentage Column 1 Percent compare Thresholds is: 0.4.0.1.0.15 |
[2017-06-23 18:07:28] |
Those percentages definitely are not correct. For an understanding of how the percentages should be set, refer to: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#TextColoringBasedOnDominantSideAskVolBidVolPercentage That documentation is for dominant side coloring but is also applicable to diagonal dominant as well in regards to understanding percentages. Also, these percentages must be in ascending order from left to right. They currently are not. They are reverse of that. Each number must also be separated by a comma character. So this uses the English system where the decimal point delimiter is a . and the delimiter between the numbers is a comma character (,). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-23 19:50:23
