Date/Time: Sat, 11 May 2024 11:22:28 +0000
Pullback Column Separator
View Count: 718
[2017-06-21 14:09:22] |
BenjaminR - Posts: 168 |
Hi SCE: Is there a way currently, to create a space/small gap between the numbers bars and the pullback column? I tried creating a 'transparent' one in the first pullback column, but that doesn't seem to work. I've used the separator line, but it's not ideal. If there is not, it would be great if this was implemented - it would greatly enhance readability. Thank you, Ben |
[2017-06-21 17:58:55] |
This is controlled through this Input: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_PullbackColumnRightOffsetInPixels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
