Date/Time: Sun, 12 May 2024 19:34:22 +0000
Copy Chart Drawings from Chart #'s
View Count: 839
[2017-06-21 12:14:26] |
User46129 - Posts: 22 |
From SC Help File: "Chart Drawings that are copied to another chart from a source chart, cannot be interacted with." This is seems to work when copying from bar chart to bar chart, but when I copy from bar chart to a TPO chart, I am able to interact with copied drawings. Often, when moving a chart with the hand tool, I will accidentally grab a drawing and move it, then have to go back to the original chart and fix... Is there a way to avoid this? Update: actually, after messing around with this some more, I find that I can edit drawings when copying from bar chart to bar chart, as well... Date Time Of Last Edit: 2017-06-21 12:24:11
[2017-06-21 18:46:05] |
Yes, you need to uncheck this option in Chart Settings: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#AllowModificationOfChartDrawingsFromOtherCharts The documentation has also been updated. The particular section you quoted, was out of date. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
