Date/Time: Sun, 12 May 2024 09:12:55 +0000
Display Bar Values
View Count: 1646
[2017-06-20 12:08:43] |
RonW - Posts: 103 |
Is there a way that if I hover over/select a candlestick bar with the pointer or crosshair I can see the OHLC values for that bar? I thought "Chart Values Window" would do it, but I can only get that to display the values of the last bar on the chart. Thanks. |
[2017-06-21 00:33:58] |
Refer to: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
