Date/Time: Sat, 18 May 2024 15:41:00 +0000
Is it possible to run 2 Sierra charts on different computer
View Count: 1257
[2017-06-16 14:58:52] |
User122550 - Posts: 8 |
I have created my second sub account and I have created my own automated trading system through Sierra. can I run 2 different username(but same 1 account) on 2 different computer? 1st main account for my 1st computer and 2nd sub account for my 2nd computer? |
[2017-06-16 15:02:09] |
You can use Sierra Chart on two different computers and use the same Sierra Chart Account Name. You do not need another account.
[2017-06-16 15:07:16] |
I have tried it just now again but If one is connected the other will not connect. As I mentioned I am not logging in with same username(just 1 account) for different computers. 1 username(but 2 accounts under 1 username) for 2 different computers. Using Sierra through Gain data feed and they told me there could be possible extra fees for this type of settings. |
[2017-06-16 15:10:47] |
This is due to a limitation with the particular Trading service you are connecting to which is Gain Capital. Sierra Chart itself has no restrictions in this regard.You will need to contact them and have them set you up with a completely separate Gain Capital username. You will enter that into Global Settings >> Data/Trade Service Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-16 15:11:07
