Date/Time: Sat, 18 May 2024 20:20:34 +0000
DRAWSTYLE_VALUE_ON_HIGH
View Count: 744
[2017-06-15 20:07:58] |
User53601 - Posts: 105 |
Hello, DRAWSTYLE_VALUE_ON_HIGH displays the mumber as a real number (4.00). What settings is needed to display it as an integer number (4) ? thank you |
[2017-06-16 02:26:03] |
This is going to be affected by the Value Format setting of the study. For instructions to change this, refer to: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-16 02:26:33
