Date/Time: Mon, 06 May 2024 19:36:05 +0000
New Method to Make Continuous Contract Back Adjustment Changes
View Count: 2356
[2017-06-15 16:42:11] |
In version 1570 there is now a much easier and simple method to adjust the Continuous Futures Contract Back Adjustment amounts at each rollover. This is now documented here: Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-15 16:44:25
[2017-06-15 17:49:17] |
AKR - Posts: 523 |
I did try. seems this only adjust that one chart. Does this mean I am supposed to enter this now to EACH ES (or what ever symbol) chart window I am using?
[2017-06-15 17:53:42] |
AKR - Posts: 523 |
ah and I meant the settlement price of wednesday, not closing. does n´t that make even more sense?
[2017-06-15 17:55:58] |
Yes. But we see that this would be difficult. So we will make it a Global Symbol Setting instead.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-15 17:56:04
