Date/Time: Sun, 19 May 2024 02:57:34 +0000
Hang Seng index
View Count: 1549
[2017-06-14 18:18:18] |
User989712 - Posts: 27 |
Hello, I want to test trade the Hang Seng Index What do I need to: 1) SIM Trade 2) Live Trade Thanks |
[2017-06-14 18:24:32] |
For live trading this market you will need to use Interactive Brokers: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php For simulated trading use Trade Simulation Mode: http://www.sierrachart.com/index.php?page=doc/TradeSimulation.php For the real-time market data for the HSI futures you will need to use the Sierra Chart Exchange Data Feed and activate the Hong Kong Futures Exchange: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-14 19:33:39] |
Hello, Thank you...is IB the only broker? Because from what I remember they are not scalper friendly... I didn't like my interactions with them some time ago. Is CQG only a data feed...or a broker also? :-) |
[2017-06-14 19:42:39] |
You can use a broker supporting CQG as well. There are many of them. Refer to: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-14 20:09:09] |
Ok, thanks. I have an account with Ampfutures but they don't offer HSI on CQG. Will have to look further.
[2017-06-15 13:09:30] |
ah...looked at the fees for the HSI and not possible to scalp... :-) |
