Date/Time: Sun, 19 May 2024 12:35:47 +0000
Keyboard shortcuts for chartbooks
View Count: 1440
[2017-06-13 07:31:18] |
AlexPereira - Posts: 197 |
Hi, If possible I would like to request a feature for keyboard shortcut for specific chartbooks. For example, I would like for ALT+1 to open a specific chartbook, and ALT+2 to open another and so on. Currently I am using the File menu -> Quick open 1,2,3 keyboard shortcuts, but its problematic, if I open chartbooks in a different order. The ideal would be for the same shortcut to always open the same chartbook, or quickly switch to it if already open. Thanks!!! |
[2017-06-13 17:43:53] |
Instead of Keyboard shortcuts there are Control Bar buttons for Chartbooks: http://www.sierrachart.com/index.php?page=doc/ControlBar.php#ControlBarChartbookButtons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-13 19:44:06] |
Yes, that is also what I am using. I am asking because I have mainly a control bar on every chart just for that, and keyboard shortcuts would be much handier for me. ( I have almost everything in SierraChart driven by keyboard ) Is it possible, when you have time and availability for it, to develop that feature ? |
