Date/Time: Thu, 16 May 2024 01:10:16 +0000
Two datafeeds
View Count: 1041
[2017-06-08 18:42:44] |
User60579 - Posts: 41 |
If I install two different datafeeds in two instances of Sierra chart like you describe in the manual, is it possible to have one symbol from one datafeed and one symbol from the other below in the SAME chart? I would like to use JTFT.Z (FTSE 100 ISSUES NET TICK) from IQ feed below my CQG symbol. Cheers |
[2017-06-08 18:51:01] |
Yes, this is supported. Refer to: https://www.sierrachart.com/index.php?page=doc/FileMenu.html#FileFindSymbol_OpenChartFromAnotherInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-08 18:51:02] |
[2017-06-12 08:27:51] |
Is it possible Replaying charts with two symbols from two instances of Sierra Chart? Cheers |
[2017-06-12 14:50:13] |
To do this you need to open a chart data file from a remote instance. This is documented here: https://www.sierrachart.com/index.php?page=doc/FileMenu.html#FileFindSymbol_OpenChartFromAnotherInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-12 14:50:36
