Date/Time: Mon, 13 May 2024 00:07:36 +0000
chart scale for number bars
View Count: 1397
[2017-06-07 13:39:26] |
Yamin2000 - Posts: 31 |
Hi I am volfix user trying sierra chart in demo mode before i move to here. trying to scale the number bars chart to fit my chart to easy spot support and resistance but it does not fit ,Does playing with chart tick scale affect my trading result?(I TRADE USA STOCKS ONLY) And does the demo data accurate because bid and ask numbers different than volfix ? http://www.sierrachart.com/image.php?Image=1496842711638.png Date Time Of Last Edit: 2017-06-07 13:49:24
[2017-06-07 19:02:33] |
You definitely need to increase the Tick Size for a high-value stock like that. Refer to: Numbers Bars: Adjusting Tick Size For Larger Increment And does the demo data accurate because bid and ask numbers different than volfix ? This is not demo data and it is accurate. The data is the same as a paid account.
