Date/Time: Fri, 10 May 2024 07:26:31 +0000
User Question
View Count: 659
[2017-06-07 02:12:32] |
Sierra Chart - Max - Posts: 5608 |
-Can you use an alarm that sends email ??? -Sierra work with trading system ?? -How can I build chart spread trading? 1. Yes, refer to the documentation here: General Settings Window: E-mail Notifications for Alerts 2. Yes. Sierra Chart Support |
[2017-06-07 18:44:29] |
Alerts do support the sending of email messages. Refer to: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings 2. Automated trading is supported. Refer to: Automated Trading Management 3. Did you want to trade exchange traded spreads or just want to create a spread chart? For a spread chart, use this study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=3#Difference_-_Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-07 18:45:04
