Date/Time: Thu, 02 May 2024 17:41:39 +0000
Poloniex Exchange
View Count: 7243
[2017-08-14 13:16:13] |
Filling in the missing data is something we have to do. We ran into a problem with that over the weekend. Going to look at it again today.
[2017-08-14 13:17:37] |
vbmithr - Posts: 204 |
I added the missing data from this night in the data server too. So when you do you will be able to fill all gaps including the recent one.
[2017-08-14 13:19:26] |
Queeq - Posts: 42 |
Would we have to delete and reload the data or SC would detect new data by itself?
[2017-08-14 13:20:03] |
Probably you will have to "delete and download data" yes.
[2017-08-20 10:00:20] |
User35475 - Posts: 12 |
BTCUSD-BTCE daily and intraday charts do update only to the date 25.07.2017. The date range is locked to that date and can not be changed because the field in chart settings is gray. There is no connection problem because BITFINEX data updating correctly. Delete all data and download operation does not solve this problem because the unchangeable settings for date range for data download are the same as with BTCUSD data. Software version: 1594 | 2017-08-20 13:22:49 Safe Mode enabled | 2017-08-20 13:22:49 Usage end date: 2018-06-26 | 2017-08-20 13:22:49 Enabled for: Advanced Features. | 2017-08-20 13:22:49 Enabled for: Sierra Chart Historical Data Service. | 2017-08-20 13:22:49 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-08-20 13:22:49 Current selected Data/Trading service: Bitcoin Data - All Services | 2017-08-20 13:22:49 Chart Update Interval: 1000 | 2017-08-20 13:22:49 Time Zone: +04:00:00 (ST+03DT+01,M3.5.0/02:00,M10.5.0/02:00) | 2017-08-20 13:22:49 2017-08-20 12:22:48 Local computer time | 2017-08-20 13:22:49 2017-08-20 09:22:48 Local computer time in UTC | 2017-08-20 13:22:49 2017-08-20 13:22:48 Local computer time in SC Time Zone | 2017-08-20 13:22:49 Program path: C:\SierraChart\ | 2017-08-20 13:22:49 Data Files path: C:\SierraChart\Data\ | 2017-08-20 13:22:49 OS Version Number: 10.0 | 2017-08-20 13:22:49 Locale Setting: C | 2017-08-20 13:22:49 BTCUSD-BTCE Daily #1 | Reloading chart. | 2017-08-20 13:23:44 SC DTC Data with Market Depth | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2017-08-20 13:23:57 DTC Client (13) | Initiating close of socket by core. | 2017-08-20 13:23:57 DTC Client (13) | Shutdown started. Waiting for graceful close. | 2017-08-20 13:23:57 SC DTC Data with Market Depth | Disconnected from the server. | 2017-08-20 13:23:57 DTC Client (13) | Socket gracefully closed by remote side. | 2017-08-20 13:23:57 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-20 13:23:57 DTC Client (13) | Closed. | 2017-08-20 13:23:57 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2017-08-20 13:23:59 DTC Client (17) | Creating socket. | 2017-08-20 13:23:59 DTC Client (17) | Connecting to IP: 192.81.56.146. | 2017-08-20 13:23:59 SC DTC Data with Market Depth | Connected to server. | 2017-08-20 13:24:01 SC DTC Data with Market Depth | Starting socket receive thread. | 2017-08-20 13:24:01 SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-08-20 13:24:01 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-08-20 13:24:02 SC DTC Data with Market Depth | Sending logon request message. | 2017-08-20 13:24:02 SC DTC Data with Market Depth | Received logon response. | 2017-08-20 13:24:03 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-08-20 13:24:03 SC DTC Data with Market Depth | Server protocol version: 7. Client protocol version: 7 | 2017-08-20 13:24:03 SC DTC Data with Market Depth | Successfully connected. | 2017-08-20 13:24:03 SC DTC Data with Market Depth | Trading is not supported. | 2017-08-20 13:24:03 Intraday data recording state for symbol BTCUSD-BTCE is set to download 'Pending'. | 2017-08-20 13:24:03 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BTCE | 2017-08-20 13:24:03 Intraday data recording state for symbol ETHUSD-BTCE is set to download 'Pending'. | 2017-08-20 13:24:03 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BTCE | 2017-08-20 13:24:03 Delaying start of download for BTCUSD-BTCE | 2017-08-20 13:24:03 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BTCE | 2017-08-20 13:24:03 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BTCE | 2017-08-20 13:24:04 HD Request # 7 | Downloading Intraday chart data for BTCUSD-BTCE to the file BTCUSD-BTCE.scid. Service: btce | 2017-08-20 13:24:08 HD Request # 7 | Download start date-time: 2017-07-25 14:48:05.000 | 2017-08-20 13:24:08 HD Request # 7 | Using server: ds3.sierracharts.com port 10150 | 2017-08-20 13:24:08 Socket (18) | Creating socket. | 2017-08-20 13:24:08 Socket (18) | Connecting to IP: 65.182.172.42. | 2017-08-20 13:24:08 HD Request # 7 | Setting DTC encoding to Binary VLS | 2017-08-20 13:24:11 HD Request # 7 | Sending historical data logon request message. | 2017-08-20 13:24:11 HD Request # 7 | Requesting Intraday data. Start date-time: 2017-07-25 14:48:05. Record interval: 60. Symbol: BTCUSD-BTCE | 2017-08-20 13:24:12 HD Request # 7 | Decompressing data. | 2017-08-20 13:24:12 HD Request # 7 | Receiving Intraday data for BTCUSD-BTCE starting at 2017-07-25 14:48:05 | 2017-08-20 13:24:12 HD Request # 7 | Timestamp of first Intraday data file record written: 2017-07-25 14:48:05 | 2017-08-20 13:24:12 Socket (18) | Initiating close of socket by core. | 2017-08-20 13:24:12 Socket (18) | Shutdown started. Waiting for graceful close. | 2017-08-20 13:24:12 Socket (18) | Socket gracefully closed by remote side. | 2017-08-20 13:24:12 Socket (18) | Closed. | 2017-08-20 13:24:12 Historical data download thread signaled to stop. | 2017-08-20 13:24:12 HD Request # 7 | Received 1 record from 2017-07-25 14:48:05 to 2017-07-25 14:48:05 (0.0 seconds) and wrote 1 record for BTCUSD-BTCE | 2017-08-20 13:24:12 HD Request # 7 | Intraday download COMPLETE for BTCUSD-BTCE. Completion time: 4s. Unique request ID: 6 | 2017-08-20 13:24:12 Removed historical data download ID 6 | 2017-08-20 13:24:12 Real-time Intraday chart data file updates started for BTCUSD-BTCE | 2017-08-20 13:24:12 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BTCE.scid | 2017-08-20 13:24:12 Intraday chart data file opened for BTCUSD-BTCE | 2017-08-20 13:24:12 HD Request # 8 | Downloading Intraday chart data for ETHUSD-BTCE to the file ETHUSD-BTCE.scid. Service: btce | 2017-08-20 13:24:12 HD Request # 8 | Download start date-time: 2017-07-25 14:48:10.000 | 2017-08-20 13:24:12 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2017-08-20 13:24:12 Socket (19) | Creating socket. | 2017-08-20 13:24:12 Socket (19) | Connecting to IP: 192.81.56.146. | 2017-08-20 13:24:12 HD Request # 8 | Setting DTC encoding to Binary VLS | 2017-08-20 13:24:12 HD Request # 8 | Sending historical data logon request message. | 2017-08-20 13:24:12 HD Request # 8 | Requesting Intraday data. Start date-time: 2017-07-25 14:48:10. Record interval: 60. Symbol: ETHUSD-BTCE | 2017-08-20 13:24:12 HD Request # 8 | Decompressing data. | 2017-08-20 13:24:13 HD Request # 8 | Receiving Intraday data for ETHUSD-BTCE starting at 2017-07-25 14:48:10 | 2017-08-20 13:24:13 HD Request # 8 | Timestamp of first Intraday data file record written: 2017-07-25 14:48:10 | 2017-08-20 13:24:13 Socket (19) | Initiating close of socket by core. | 2017-08-20 13:24:13 Socket (19) | Shutdown started. Waiting for graceful close. | 2017-08-20 13:24:13 Socket (19) | Socket gracefully closed by remote side. | 2017-08-20 13:24:13 Historical data download thread signaled to stop. | 2017-08-20 13:24:13 Socket (19) | Closed. | 2017-08-20 13:24:13 HD Request # 8 | Received 1 record from 2017-07-25 14:48:10 to 2017-07-25 14:48:10 (0.0 seconds) and wrote 1 record for ETHUSD-BTCE | 2017-08-20 13:24:13 HD Request # 8 | Intraday download COMPLETE for ETHUSD-BTCE. Completion time: 1s. Unique request ID: 7 | 2017-08-20 13:24:13 Removed historical data download ID 7 | 2017-08-20 13:24:13 Real-time Intraday chart data file updates started for ETHUSD-BTCE | 2017-08-20 13:24:13 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BTCE.scid | 2017-08-20 13:24:13 Intraday chart data file opened for ETHUSD-BTCE | 2017-08-20 13:24:13 |
[2017-08-20 10:14:23] |
Queeq - Posts: 42 |
BTC-e is down since then.
[2017-08-20 13:51:39] |
BTC-E was shut down by US government authorities: https://btc-e.com/index.html They are history at this point in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-20 13:52:06
[2017-08-20 16:16:37] |
Queeq - Posts: 42 |
BTC-e promises to come back in the end of August, most likely under new brand. Search bitcointalk.org or reddit for more information.
[2017-08-20 18:10:24] |
OK, let us know when that is available.
[2017-08-23 05:57:34] |
Regarding the missing data for Poloniex which began August 2, all of that has now been filled in. Follow the instructions here to download the missing data: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart And we apologize for the long delay with this. If there is missing data again we will not take that long. We also would like to announce, that Sierra Chart is going to be working on direct integration to Poloniex for data and trading. This will provide the most reliable and stable access. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-23 06:22:32] |
Queeq - Posts: 42 |
Great news, thanks! There is also Bittrex, which has more currencies than Poloniex and starts pulling some volume. Any chance it could also be integrated? Overall, any plans for wider coverage of cryptocurrency exchanges? Maybe as a part of paid packages? This could be good timing now to introduce it given how cryptomarkets are getting more and more attention now. It is painful to witness how your competitors have this (Trading View, Coinigy) while you do not. |
[2017-08-23 13:46:28] |
. It is painful to witness how your competitors have this (Trading View, Coinigy) while you do not. Have what specifically?Also, there would be automatic compatibility with these exchanges if they would adopt the DTC Protocol which they should: https://www.DTCprotocol.org Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-23 13:47:04
[2017-08-23 14:18:57] |
Queeq - Posts: 42 |
Have integration with other exchanges.DTC is good. I'll raise tickets with exchanges I'm interested in to add support for it. It could be more efficient if you contacted them directly as well. I don't know what triggers your actions, but Bittrex is the one worth looking at. |
[2017-09-06 06:48:45] |
Queeq - Posts: 42 |
As promised, informing that BTC-e has resurrected on the domain btc-e.nz. Trading is disabled though.
[2018-01-06 13:02:00] |
User787215 - Posts: 14 |
Hello, I have problem with the display of volume by price for Poloniex, i got two huge rectangle (green and red). I have verified the process with Volume By Price Study but still not working Market depth historical not working for me also Is it possible to fix ? EDIT: Working on some chart (USDT-ETH) but not BTC-STR for exemple, and by the way its not STR anymore but XLM Stellar changed the name of the symbol Date Time Of Last Edit: 2018-01-07 17:16:09
