Date/Time: Fri, 03 May 2024 00:30:57 +0000
Poloniex Exchange
View Count: 7244
[2017-06-03 06:34:20] |
User733502 - Posts: 44 |
Hi SC, Is there an issue with Historical Data from Poloniex for the BTCETH symbol? JS |
[2017-06-03 21:41:18] |
There is a problem with the Poloniex data at this moment. It is delayed by six hours and the bid and ask prices are not correct. We have contacted the particular developer responsible for this about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-09 05:56:22] |
Queeq - Posts: 42 |
Poloniex data service has been down since the 1st of June. Is there any forecast when could it be fixed? Is this an issue on the exchange side? If yes, we, as their users, can push from our side as well. |
[2017-06-09 15:50:42] |
We have contacted the developer of the gateway used for Poloniex about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-10 18:08:23
[2017-06-10 13:08:33] |
vbmithr - Posts: 204 |
Hi there. I'm in charge for providing Poloniex data in Sierra Chart. As far as I can see, the Poloniex service is not down. However, it is indeed delayed by like 5 hours, and bid/ask prices are the prices from 5 hours ago. I have no idea why is it like that, it is just that the data that Poloniex send through their websocket feed is delayed by 5 hours. I don't think it is intentional (I hope not, in any case). Queeq, when you say Poloniex is down, you mean that you cannot connect to it, or that the data is not correct? Best, Vincent |
[2017-06-10 16:49:57] |
Queeq - Posts: 42 |
Hi Vbmithr, Here's what I see for all Poloniex symbols: Delaying start of download for BTC_ETC-PLNX | 2017-06-10 16:43:20 Poloniex Crypto Currency Exchange - DTC (Data) | Received logon response. | 2017-06-10 16:43:21 Poloniex Crypto Currency Exchange - DTC (Data) | Server Name: SC Realtime Server. | 2017-06-10 16:43:21 Poloniex Crypto Currency Exchange - DTC (Data) | Server protocol version: 7. Client protocol version: 7 | 2017-06-10 16:43:21 Poloniex Crypto Currency Exchange - DTC (Data) | Successfully connected. | 2017-06-10 16:43:21 Poloniex Crypto Currency Exchange - DTC (Data) | Trading is not supported. | 2017-06-10 16:43:21 Poloniex Crypto Currency Exchange - DTC (Data) | Restarting real-time data updates for symbol: BTC_ETC-PLNX | 2017-06-10 16:43:21 Symbol Error - BTC_ETC-PLNX is unknown, unavailable, or improperly formatted. Symbol service code not specified. | 2017-06-10 16:43:21 HD Request # 3 | Downloading Intraday chart data for BTC_ETC-PLNX to the file BTC_ETC-PLNX.scid. Service: Poloniex.CryptoCurrencyExchange.DTC | 2017-06-10 16:43:21 HD Request # 3 | Download start date-time: 2017-06-01 08:15:19.000 | 2017-06-10 16:43:21 HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2017-06-10 16:43:21 Socket (7) | Creating socket. | 2017-06-10 16:43:21 Socket (7) | Connecting to IP: 65.182.172.42. | 2017-06-10 16:43:21 HD Request # 3 | Setting DTC encoding to Binary VLS | 2017-06-10 16:43:22 HD Request # 3 | Sending historical data logon request message. | 2017-06-10 16:43:22 Socket (7) | Initiating close of socket by core. | 2017-06-10 16:43:22 HD Request # 3 | Error downloading historical Intraday data for BTC_ETC-PLNX. Historical data logon error: Data files folder not set for service code: Poloniex.CryptoCurrencyExchange.DTC | 2017-06-10 16:43:22 Socket (7) | Shutdown started. Waiting for graceful close. | 2017-06-10 16:43:22 Socket (7) | Socket gracefully closed by remote side. | 2017-06-10 16:43:22 Socket (7) | Closed. | 2017-06-10 16:43:22 Historical data download thread signaled to stop. | 2017-06-10 16:43:22 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for BTC_ETC-PLNX | 2017-06-10 16:43:22 HD Request # 3 | Intraday download COMPLETE for BTC_ETC-PLNX. Completion time: 1s. Unique request ID: 2 | 2017-06-10 16:43:22 Removed historical data download ID 2 | 2017-06-10 16:43:22 Real-time Intraday chart data file updates started for BTC_ETC-PLNX | 2017-06-10 16:43:22 Opened cached Intraday file: C:\SierraChart\Secondary_instance\Data\BTC_ETC-PLNX.scid | 2017-06-10 16:43:22 Intraday chart data file opened for BTC_ETC-PLNX | 2017-06-10 16:43:22 This has started on June 1st, and thus there is no data available since then. |
[2017-06-10 17:44:52] |
Can you sure you are on the latest prerelease version and do a full symbol reset (http://www.sierrachart.com/index.php?l=doc/GlobalSymbolSettings.php#FullResetSymbolSettingsSteps) ? I can't reproduce.
[2017-06-10 18:21:09] |
We apologize for not looking into this more closely with the user and also not verifying that the data had actually stopped around June 1. It is delayed but only by a few hours. The log in post #6 indicates an issue with that particular version and also the Symbol Settings are not correct either. Update to the current version: Software Download: Fast Update And perform a Full Reset of the Symbol Settings as previously explained: http://www.sierrachart.com/index.php?l=doc/GlobalSymbolSettings.php#FullResetSymbolSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-10 18:21:38
[2017-06-10 20:04:34] |
Queeq - Posts: 42 |
This has helped, thanks! And it is delayed indeed. Would it help if I opened a ticket with them? |
[2017-06-13 09:23:16] |
They are just in the process of changing their websocket feed, with obviously no notice whatsoever. Please don't use Poloniex for anything serious! :) |
[2017-06-13 10:23:31] |
In any case, I'm upgrading Poloniex to the new format. Edit: Done. Hopefully this should be correct by now. On the Poloniex Data Server in Sierra Chart, I have a market depth issue, that I can't reproduce in local. Please perform a full reset just in case. Date Time Of Last Edit: 2017-06-13 15:21:14
[2017-08-06 16:57:34] |
Queeq - Posts: 42 |
Hi vbmithr, Has anything changed on the Poloniex side again? I'm not able to get data later than the 2nd of August. Here's the log (similar for all symbols): HD Request # 13 | Sending historical data logon request message. | 2017-08-06 16:50:48 HD Request # 13 | Requesting Intraday data. Start date-time: 2017-08-02 18:50:00. Record interval: 10. Symbol: BTC_ETC-PLNX | 2017-08-06 16:50:48 HD Request # 13 | Decompressing data. | 2017-08-06 16:50:48 HD Request # 13 | Receiving Intraday data for BTC_ETC-PLNX starting at 2017-08-02 18:50:00 | 2017-08-06 16:50:48 HD Request # 13 | Timestamp of first Intraday data file record written: 2017-08-02 18:50:00 | 2017-08-06 16:50:48 Socket (26) | Initiating close of socket by core. | 2017-08-06 16:50:48 Socket (26) | Shutdown started. Waiting for graceful close. | 2017-08-06 16:50:48 Socket (26) | Socket gracefully closed by remote side. | 2017-08-06 16:50:48 Socket (26) | Closed. | 2017-08-06 16:50:48 Historical data download thread signaled to stop. | 2017-08-06 16:50:48 HD Request # 13 | Received 1 record from 2017-08-02 18:50:00 to 2017-08-02 18:50:00 (0.0 seconds) and wrote 1 record for BTC_ETC-PLNX | 2017-08-06 16:50:48 HD Request # 13 | Intraday download COMPLETE for BTC_ETC-PLNX. Completion time: 11s. Unique request ID: 11 | 2017-08-06 16:50:48 Could you help fix this once again, please? |
[2017-08-06 16:59:19] |
Let me check. Edit: Cannot reproduce. Everything works fine for me. As far as I can see. Date Time Of Last Edit: 2017-08-06 17:04:09
[2017-08-06 17:22:35] |
Queeq - Posts: 42 |
Is there a way to debug it somehow?
[2017-08-06 20:43:34] |
How do you come to this conclusion?We confirm that your Poloniex server is not providing real-time trade or market depth data as of 2017-08-02. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-06 20:43:53
[2017-08-06 20:44:02] |
User35475 - Posts: 12 |
Same problem here. All intraday and historical Poloniex data has been stopping updating past the 2nd august. The same happens also with fresh data downloads to chosen new symbols as BTC_ETH-PLNX daily. Software version: 1594 | 2017-08-07 00:29:33 Usage end date: 2018-06-26 | 2017-08-07 00:29:33 Enabled for: Advanced Features. | 2017-08-07 00:29:33 Enabled for: Sierra Chart Historical Data Service. | 2017-08-07 00:29:33 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-08-07 00:29:33 Current selected Data/Trading service: Poloniex Crypto Currency Exchange - DTC | 2017-08-07 00:29:33 Chart Update Interval: 500 | 2017-08-07 00:29:33 Time Zone: +04:00:00 (ST+03DT+01,M3.5.0/02:00,M10.5.0/02:00) | 2017-08-07 00:29:33 2017-08-06 23:29:33 Local computer time | 2017-08-07 00:29:33 2017-08-06 20:29:33 Local computer time in UTC | 2017-08-07 00:29:33 2017-08-07 00:29:33 Local computer time in SC Time Zone | 2017-08-07 00:29:33 2017-08-06 17:58:07 Server time in UTC | 2017-08-07 00:29:33 Local computer UTC time and Server UTC time difference: 3 seconds. | 2017-08-07 00:29:33 Program path: C:\SierraChart\ | 2017-08-07 00:29:33 Data Files path: C:\SierraChart\Data\ | 2017-08-07 00:29:33 OS Version Number: 10.0 | 2017-08-07 00:29:33 Locale Setting: C | 2017-08-07 00:29:33 USDT_BTC-PLNX 8000 Trades #1 | Reloading chart. | 2017-08-07 00:30:17 XXX BTC_ETH-PLNX Daily #1 | Reloading chart. | 2017-08-07 00:36:01 BTC_ETH-PLNX Daily #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BTC_ETH-PLNX.dly | 2017-08-07 00:36:01 Poloniex Crypto Currency Exchange - DTC | Starting real-time market data updates for: BTC_ETH-PLNX. ID: 4 | 2017-08-07 00:36:02 Poloniex Crypto Currency Exchange - DTC | Requesting security definition data for: BTC_ETH-PLNX. ID: 4 | 2017-08-07 00:36:02 HD Request # 33 | Downloading Historical Daily chart data for BTC_ETH-PLNX. Starting date: 1967-08-07. Service: Poloniex.CryptoCurrencyExchange | 2017-08-07 00:36:02 HD Request # 33 | Using server: ds3.sierracharts.com port 10150 | 2017-08-07 00:36:02 Socket (137) | Creating socket. | 2017-08-07 00:36:02 Socket (137) | Connecting to IP: 65.182.172.42. | 2017-08-07 00:36:02 Poloniex Crypto Currency Exchange - DTC | Received security definition for symbol BTC_ETH-PLNX | 2017-08-07 00:36:03 Poloniex Crypto Currency Exchange - DTC (Data) | Received security definition for symbol BTC_ETH-PLNX | 2017-08-07 00:36:03 HD Request # 33 | Setting DTC encoding to Binary VLS | 2017-08-07 00:36:03 HD Request # 33 | Sending historical data logon request message. | 2017-08-07 00:36:03 HD Request # 33 | Requesting historical Daily data starting at 1967-08-07. | 2017-08-07 00:36:03 HD Request # 33 | Decompressing data. | 2017-08-07 00:36:03 HD Request # 33 | Receiving historical Daily data for BTC_ETH-PLNX starting at 2015-08-08 | 2017-08-07 00:36:11 HD Request # 33 | Writing historical Daily data to the file BTC_ETH-PLNX.dly | 2017-08-07 00:36:11 Socket (137) | Initiating close of socket by core. | 2017-08-07 00:36:11 Socket (137) | Shutdown started. Waiting for graceful close. | 2017-08-07 00:36:11 Socket (137) | Socket gracefully closed by remote side. | 2017-08-07 00:36:11 Socket (137) | Closed. | 2017-08-07 00:36:11 Historical data download thread signaled to stop. | 2017-08-07 00:36:11 HD Request # 33 | Received 534 records from 2015-08-08 00:00:00 to 2017-08-02 00:00:00 (726.0 days) and wrote 477 records for BTC_ETH-PLNX | 2017-08-07 00:36:11 HD Request # 33 | Daily download COMPLETE for BTC_ETH-PLNX. Completion time: 9s. Unique request ID: 29 | 2017-08-07 00:36:11 Removed historical data download ID 29 | 2017-08-07 00:36:11 |
[2017-08-06 20:44:54] |
See post #15 above. We confirm this as well.
[2017-08-06 21:34:46] |
I've restarted the server. It seems to work now. I'll investigate later on.
[2017-08-06 21:59:32] |
Do you have price history for the symbols so we can fill in the missing historical data? We have not checked.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-23 05:55:52
[2017-08-07 07:19:17] |
Queeq - Posts: 42 |
I confirm that it works now, thanks! But there's gap in data...
[2017-08-07 09:55:59] |
Sure I will soon deploy the data server in order for SC to fetch the missing data.
[2017-08-14 12:53:01] |
Queeq - Posts: 42 |
The issue has appeared again.
[2017-08-14 12:53:30] |
Let me see! Edit: Restarted the server, it died in the middle of the night, I need to setup auto-restart when it happens. Sorry about that. Date Time Of Last Edit: 2017-08-14 12:58:53
[2017-08-14 13:13:15] |
Queeq - Posts: 42 |
Thanks. Is there any ETA for filling gaps in data? |
[2017-08-14 13:16:13] |
Filling in the missing data is something we have to do. We ran into a problem with that over the weekend. Going to look at it again today.
