Date/Time: Wed, 15 May 2024 04:01:57 +0000
Support for stock/index/futures option
View Count: 849
[2017-05-29 09:14:56] |
User543777 - Posts: 7 |
Hi, It would be great to complete this missing puzzle piece. Option is a big miss in this fantastic platform. BRs, Jia |
[2017-05-29 13:08:42] |
For Interactive Brokers all of these types of options are supported. Refer to the symbol formats here: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-29 13:11:01] |
Oh, good to know, thank you. Do you also support international index options such as Hongkong, Japan and Korea?
[2017-05-29 13:19:14] |
If you are using Interactive Brokers any symbol Interactive Brokers supports is also supported by Sierra Chart.
[2017-05-29 14:31:53] |
Great to hear that, thank you for reply. Sierra is the best! :)
[2017-06-29 05:02:42] |
Let us know if you need help with the prior question which is now hidden.
[2017-06-29 06:48:18] |
No more issue. I've deleted the question. Thank you Jia |
