Date/Time: Mon, 20 May 2024 09:34:31 +0000
several price graphs in one chart
View Count: 693
[2017-05-28 14:53:55] |
User39772 - Posts: 311 |
Hello how can I didplay several price graphs in the same chart window, e.g.two different stocks etc. It would be sufficient if the seconnd price chart can be displayed like an indicator. |
[2017-05-28 16:14:03] |
Refer to instructions here: Working With Charts: Overlaying Multiple Symbols in a Single Chart Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-28 16:14:15
[2017-05-28 16:26:18] |
Thx, it works fine for lines. When I try to overly a cnadlestick chart the candles look somehow distorted, i.e. they are not as clear displayed in the overlay compared to the referenced chart.
[2017-05-28 17:21:35] |
What study did you use? Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
