Date/Time: Fri, 03 May 2024 11:10:49 +0000
Order of charts from task bar
View Count: 989
[2017-05-22 20:33:41] |
trader1 - Posts: 128 |
Hi, I have a lot of detached charts on my layouts. Usually the main chart shows up on top of the list as accessed from the task bar, but occasionally the main chart is the last one listed and I have to scroll through all of them until I get to the main one to change global settings, etc. Is there a way to sort them or make the main chart show up on top? Thanks. |
[2017-05-23 00:44:49] |
User19165 - Posts: 346 |
Yeah I have the same thing sort of. I like to use alt-tab a lot to find things but there is a huge amount of windows stacked from Sierra when I alt-tab. Ideally, they would make it so that a single application is listed in the task bar and windows alt-tab list. Then you would click on Sierra in the task bar (or alt-tab) and all your Sierra previously viewed workspace comes to the foreground - detached included. I have used other charting applications that do as I describe with their detached windows (ie. Neoticker). |
[2017-05-23 04:50:00] |
There should be a way to reorder them through the Windows taskbar. It should be a drag-and-drop operation.
[2017-05-24 13:59:51] |
Drag and drop through the taskbar doesn't seem to work for me.
[2017-05-26 20:21:28] |
Any other suggestions? Thanks |
[2017-05-26 20:32:53] |
Sierra Chart - Max - Posts: 5599 |
You can check the following posts about this: https://superuser.com/questions/61913/arrange-windows-within-the-same-application-in-the-taskbar-of-windows-7 https://superuser.com/questions/364960/reorder-windows-7-taskbar-items Sierra Chart Support |
