Date/Time: Mon, 29 Apr 2024 07:26:47 +0000
Day Session Only weekly Charts - Start Date issue
View Count: 1331
[2017-05-15 17:03:36] |
User316362 - Posts: 210 |
Re: Chart Session Times: Day Session Only Weekly Chart Bars This instruction works well. However, if for instance a Sunday start date (to have the weekly start on Monday) exceeds the available data when using Transact....the start day could be a Tuesday, Wednesday etc based on how far back one places the Sunday date. If you were to look at this today.... Try using a start date of 2012-01-01 (Sunday) and the weekly bars will start on Tuesday. If you use 2012-03-04 (Sunday and data is available) the bars start correctly on Monday. And any Sunday after this date works of course. Thus I suspect that the problem occurs when the start date has no existing data. Might need a note in instructions or some fix to check this (better solution). Also, I'm wondering if the sliding window of 5 years or so of available data might cause and issue if the start date gets well behind over time. Don't know need a few weeks to see. Date Time Of Last Edit: 2017-05-15 17:06:44
[2017-05-17 04:50:37] |
We will have to look this over when we have some time. Most likely it will be months before we can get to this.
[2018-01-08 00:46:33] |
Letting you know this has been solved about two months ago.
[2018-01-08 02:30:12] |
Thanks very much!
