Date/Time: Sun, 12 May 2024 14:27:08 +0000
How to copy and crossover a study from one region to another region
View Count: 878
[2017-05-10 15:19:48] |
User73463 - Posts: 21 |
Is there any way to copy a study in one region and move it to another region?
[2017-05-10 17:16:58] |
In Analysis >> Chart Studies, there is a Duplicate button to do what you need: Chart Studies: Duplicate You will also need to change the Chart Region for the study. Refer to: Chart Studies: Study Settings Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-10 17:17:30
[2017-05-10 18:38:14] |
I may have been initially confusing. Maybe I should have said tools or drawings. For example, If I draw a triangle or Fib. Fan in Region 1, how can I duplicate the same triangle or Fib. Fan with the same anchors/angles and move it to Region 2 and vice versa? Thanks.
[2017-05-10 19:33:46] |
This is not possible. A Chart Drawing once drawn in one particular Chart Region cannot be copied to another.
