Date/Time: Sun, 12 May 2024 16:38:55 +0000
Not displaying extended hours TPO in new install. (Or pre release 1554)
View Count: 691
[2017-05-10 05:52:57] |
Rino - Posts: 124 |
Hi, I had to install my older version. (1548) When I installed the new version it did not display the TPO's for extended hours. I tried the pre-release (1554) but that did not show them either. I enclosed a snapshot but it is the older version with a note. Also the transparent background seemed weird. It was it was not really transparent. (Same with pre-release.) Thanks as always |
[2017-05-10 06:01:49] |
Rino - Posts: 124 |
I just read post 33818 from 5/9. You may already be aware of issue with the transparent feature. Thanks |
[2017-05-10 06:03:20] |
Check the Session Times: Chart Session Times Also, remove the TPO Profile Chart study from the chart to make sure the data you want to see is actually there. We also do not know what you are trying to show in the screenshot. It looks to us like there is the extended hours trading in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-10 06:04:11
[2017-05-10 06:08:31] |
Rino - Posts: 124 |
Hi, I did not make a screenshot of the problem before I went back to older version. It was just to point out new version did not have them, that's all. |
[2017-05-10 06:14:49] |
Make sure this Input on the newer versions is set to No: Time Price Opportunity (TPO) Profile Charts: Exclude Evening Session Profiles Except For Last Day Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
