Date/Time: Thu, 09 May 2024 20:06:31 +0000
Study/Price Overlay only draws dashed lines?
View Count: 1086
[2017-05-09 15:12:00] |
RonW - Posts: 103 |
(emini S&P futures through CQG Web API) I have a 24 hour chart with "High/Low for Time Period - Extended" which draws the high and low of the overnight (Globex) session. The lines are solid. I have a chart of the day session only to which I have added Study/Price Overlay to draw those overnight highs and lows on my day session chart. The levels are fine, but the lines are dashed. In Study Settings/Subgraphs, the Draw Style is Stair Step and the Line Style is Solid, but on the chart I am seeing dashed lines. Is there a way to make them solid? FYI, if I try to change the Draw Style to anything other than Stair Step, the change is not accepted and the Draw Style reverts to Stair Step. Thanks, RLW |
[2017-05-09 16:48:33] |
We do not see why this would be the case. Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-09 21:56:59] |
RonW - Posts: 103 |
http://www.sierrachart.com/image.php?Image=1494366988514.png
Image 2.png / V - Attached On 2017-05-09 21:50:47 UTC - Size: 89.23 KB - 244 views Attachment Deleted. |
[2017-05-09 22:01:25] |
RonW - Posts: 103 |
I'm trying to upload a shot of the study settings
Image 3.png / V - Attached On 2017-05-09 22:00:50 UTC - Size: 42.43 KB - 218 views |
[2017-05-10 05:24:54] |
You need to set Fill Blanks with Last Value to Yes with the Study/Price Overlay study: Study/Price Overlay Study: Fill Blanks with Last Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
