Date/Time: Wed, 25 Nov 2026 21:06:05 +0000
Is there a way to copy and paste drawing objects between charts or chart books?
View Count: 2635
[2017-05-03 12:38:01]
User176175 - Posts: 1
I'm wondering if there is a function to copy and paste drawing objects from one chart to another chart or chart book?
Any help would be great.
Thanks!
[2017-05-03 16:37:13]
Yes. Refer to:
Copying Chart Drawings from Other Charts Automatically
Date Time Of Last Edit: 2022-11-14 18:13:52
[2022-11-14 06:22:22]
User519569 - Posts: 18
Selecting the destination charts is the mystery here. There's no box to fill and no discussion of how to designate a destination chart.
[2022-11-14 10:56:44]
Yes there is. The documentation here explains how to do this,
You go to the destination chart and this is the Chart Setting for this:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
Date Time Of Last Edit: 2022-11-14 18:14:07
[2022-11-14 17:48:08]
I re-read and studied this documentation you've linked half a dozen times before my previous comment. I apologize for being a slow learner, but as best I can determine, although the term "destination chart" has been mentioned there, this patient response of yours is the very first time anyone has indicated that we need to START this process FROM the "destination" chart. Thank you for your generous help.
[2025-04-26 15:52:16]
WyckoffSleuth - Posts: 36
I see in the changelog this function has been added a few days ago
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2754
Copy and paste functionality for Chart Drawings to copy a Chart Drawing from one chart to another chart.
I can't find help articles how to use it nor can I find any changes in Sierra interface to actually copy paste the drawings. How does this work please?
[2025-04-28 15:30:25]
John - SC Support - Posts: 48659
The functionality is under the "Edit" menu. There are new items for "Copy Chart Drawing" and "Paste Chart Drawing".
Note that in order to copy a drawing, the drawing itself must be selected first, then the option for "Edit >> Copy Chart Drawing" will be available.
[2025-11-14 02:09:12]
ForgivingComputers.com - Posts: 1256
I have a tool that copies drawings between regions, charts, chartbooks, and instances. It uses CSV files that can be saved to any folder.
https://forgivingcomputers.com/product/fc-drawing-export-and-import-tools/
