Date/Time: Sun, 19 May 2024 04:37:08 +0000
save data
View Count: 566
[2017-04-28 13:25:36] |
User502561 - Posts: 36 |
Hi I would like save all transaction history with study and order flow for watch the transaction during the week end what I need to do? Regards, Massimo |
[2017-04-28 17:38:54] |
Nothing special other than setting Sierra Chart to a tick by tick data configuration. Refer to: http://www.sierrachart.com/index.php?page=doc/TickbyTickDataConfiguration.php Although because you are using Interactive Brokers you will need to use the Sierra Chart Exchange Data Feed for complete data. Refer to: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#MarketDataProblems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
