Date/Time: Sun, 19 May 2024 07:23:56 +0000
User Email
View Count: 670
[2017-04-28 00:40:07] |
Sierra Chart - Max - Posts: 5618 |
Hello Guys,
I know you provide a kind of order flow within your chart and I wanted to know if it was able for SPOT Forex trading. Coridally Sierra Chart Support |
[2017-04-28 05:34:34] |
If you are referring to the Numbers Bars feature: Numbers Bars Then this does work with spot Forex symbols. Is that your question? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
