Date/Time: Sat, 18 May 2024 05:24:44 +0000
User Email
View Count: 1040
[2017-04-18 01:29:22] |
Sierra Chart - Max - Posts: 5618 |
Can this be recreated? Bottom chart zone
There is in TOS a study HeikinAshiDiff, wondering if it could be setup in Sierra. here are a couple of imagoes. It seems to give a heads up to a direction change. Thanks Sierra Chart Support |
image001.png / V - Attached On 2017-04-18 01:29:07 UTC - Size: 47.37 KB - 242 views image002.png / V - Attached On 2017-04-18 01:29:13 UTC - Size: 144.6 KB - 246 views |
[2017-04-19 03:06:24] |
You can do this by using the Study Subgraphs Difference study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=185#Study_Subgraphs_Difference And the Moving Average study which can be based on that difference: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Also Sierra Chart has a Heikin-Ashi Smoothed study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=314#Heikin-Ashi_Smoothed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
