Date/Time: Sat, 18 May 2024 04:04:36 +0000
SC Size
View Count: 694
[2017-04-17 08:52:46] |
User14683 - Posts: 34 |
I have 4 SC's running on my computer and every SC Application runs 6 to 14 charts. The total size of each application is not larger than 800 MB. I recently made some changes to my charts and also downloaded some more data to the charts. When I made back ups of my charts, I noticed that the size of one of my SC is 6.23 GB. How do I fix this? Where can I see which charts are so big, as I do not need that much data stored? If the problem is cause by maybe tick data that I downloaded, how do I undo that? |
[2017-04-17 14:41:17] |
If you are referring to the size of Sierra Chart data files, that size is not unusual. Tick by tick data will take more space. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-17 14:42:16
[2017-04-17 15:09:59] |
What can I do to rather work with smaller files. How do I erase some of the big files and replace with minute data files? How do I see which are the big files? |
[2017-04-17 16:56:44] |
Sierra Chart - Max - Posts: 5618 |
Refer to the Intraday Data File Management documentation here: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#DataFileManagement Sierra Chart Support |
[2017-04-17 19:32:18] |
You can adjust the Intraday Data Storage Time Unit to 1 Minute: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#IntradayStorageUnit You can see the file sizes through File >> Find Symbol. And has been previously linked to, you can use the Intraday Data File Management function to reduce file sizes: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#DataFileManagement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-17 19:33:14
