Date/Time: Sun, 05 May 2024 10:49:37 +0000
Changing Study Inputs Directly from Chart
View Count: 850
[2017-04-14 03:40:09] |
QnReally - Posts: 181 |
I was trying to follow: Chart Studies: Changing Study Inputs Directly from Chart I typed the following in a chart: in:id13.in44=7 See 1.png attached. It is supposed to modify the width of the Volume By Price study (ID=13) to 7 but it changes to 3. If I tried to set it to different values like 33 and 15. Each results in the width of 3. Please see 2.png attached. I must be doing something wrong. I upgraded from v.1536 to v.1543 and I get the same result. By the way, I tried this on a Zig Zag study and that worked. Thanks. |
[2017-04-14 04:07:12] |
This is fixed. When we were correcting an earlier problem with this feature, there was an implementation problem. Surprising no one else pointed this out earlier.
[2019-06-26 04:59:32] |
Acro - Posts: 436 |
In the Market Depth Historical Graph study, Input 23 (In23) sets the percent color threshholds This is three values, separated by two commas. I cannot change this by direct input whether by typing directly or by macro from another program (eg Fastkeys). Is there any way to change these three values by direct input ? Thanks |
[2019-06-26 15:37:23] |
The Input for Percent Color Thresholds (and others like it) are Text Strings, and modifying Text Strings is not supported using the keyboard. Just for completeness, this information can be found here: Chart Studies: Changing Study Inputs Directly from Chart You can use ACSIL to change text string Inputs: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-27 04:29:40
