Date/Time: Sun, 28 Apr 2024 08:29:18 +0000
Does SC have an OsMa Indicator?
View Count: 1610
[2017-04-11 02:17:02] |
Mike_S - Posts: 42 |
OsMa Indicator Definition Moving Average of Oscillator (OsMA) is a technical analysis tool that reflects the difference between an oscillator (MACD) and its moving average (signal line). Thanks |
[2017-04-11 06:41:08] |
This can be done by using the Study Subgraphs Difference study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s227 However, the MACD study already has the calculation you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-14 16:40:30] |
User308424 - Posts: 68 |
Hi Mike, did you manage to get what you want? I also looking for an OsMA indicator for SC. Would you be able to help with that? Thanks |
[2021-01-14 17:20:51] |
Ackin - Posts: 1865 |
User308424) Custom Studies: Osma or Osma adaptive Library Free (2019) https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2021-01-14 17:21:32
image_3708.png / V - Attached On 2021-01-14 17:15:17 UTC - Size: 107.57 KB - 231 views |
[2021-01-14 18:44:31] |
User90125 - Posts: 715 |
OsMA is simply the histogram of the MACD indicator. That's it. Nothing special to see here. For context, the histogram is a recent addition to the original MACD indicator developed by Gerald Appel, back in the early 80s. |
