Date/Time: Sun, 19 May 2024 11:19:26 +0000
Automation of options trades
View Count: 598
[2017-04-06 21:16:31] |
IBUser738106 - Posts: 14 |
Is it possible to automate the trading of options? data1 - underlying data2 - applicable option |
[2017-04-07 17:46:12] |
Yes this can be done. So did you want to create an automated trading system in Sierra Chart? You would want to use the Trade and Current Quote Symbol: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TradeAndCurrentQuoteSymbol Also refer to: http://www.sierrachart.com/index.php?page=doc/ACSILTrading.html#SubmittingOrdersDifferentSymbolAccount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-07 19:05:11] |
This would be the first time I have tested the platform. Would it be possible to schedule a walk-thru via skype or teamviewer?
[2017-04-10 10:36:54] |
If there is something specific you require help for, you could request paid remote assistance support. Refer to: https://www.sierrachart.com/index.php?page=doc/support.html#Interactive Sierra Chart is also such a vast program, that the concept of a walk-through does not really make sense. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
