Date/Time: Sun, 19 May 2024 08:35:58 +0000
OHLC Ray Config with Alert
View Count: 716
[2017-04-06 04:21:07] |
nicktrader - Posts: 665 |
I'd like to configure a line like OHLC Ray with Alert but later in use it does not work as you can see in the attached file. I saved my configuration in TC7 Isn't it possible or what I have to do? |
OHLC Ray Config and Properties.png / V - Attached On 2017-04-06 04:18:21 UTC - Size: 46.45 KB - 227 views |
[2017-04-06 07:58:26] |
Refer to step 8 here: Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-08 06:24:30] |
I'd like to come back to the "Alert Option". I do not know how it works. I've tried a tousend time but no result that works. My intention is to configure a line with alert sound on crossing. If I save it on "TC1" it works perfectly but if I#d like to save it on i.e. "TC7" it do not. You gave me that link: Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition But step #5 I do not understand. If I klick on "Tools >> Current Tool Config >> Config 1-24" it is grey and not active. Is it possible to tell me step by step what I have to do, if I'd like to save it on "TC7" Many thanks |
[2017-04-08 07:58:03] |
We have updated step 5 here to make it very clear: Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-09 11:49:19] |
It does not work. Saving the config (with alert) i.e. under TC7 is not the problem. After placing a ray (for example) I am doing a doubleclick to change the properties to TC7. But than it does not work. If I save the configuration (with alert) under TC1 it works because I do not have to change anything. |
[2017-04-09 21:11:42] |
Once again step 8 here explains the reason for this and provides a solution: Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition You cannot apply a saved Alert Condition configuration through the Chart Drawing Properties window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-10 10:07:09
